E250 - Can't get my o2 sensor readiness to complete
Old Feb 13, 2023 | 05:03 PM
  #31
aquanaut20's Avatar
Originally Posted by diegob
EVAP is ready. The ONLY monitors that are not ready are O2 sensor and O2 sensor heater.
Then there are no additional test we can advise, the O2 will not set until the heater fault is remedied.
Old Feb 13, 2023 | 05:29 PM
  #32
diegob's Avatar
So how do I know that the heater is at fault if there are no codes? It just shows as incomplete. I'm trying to decide if I should keep driving or if I should take it to the shop. Thanks again.
Old Feb 13, 2023 | 07:36 PM
  #33
aquanaut20's Avatar
Redo the power test on the heater circuit, only this time instead of using a meter, use a test load (head light bulb). and confirm the ground side with the load as well.
  #34
aquanaut20's Avatar
The O2 Heater circuits use 2 common coloured wires..
Old Feb 15, 2023 | 04:15 PM
  #35
diegob's Avatar
I used a 12v light and it turns on just fine. There seems to be nothing wrong. I am at a loss, I wonder if taking out the sensors and giving them a good cleaning is worth doing, or just a waste of time. It's not yet due for an oil change (less than 5k miles with synthetic oil since the last one) but I wonder if an oil change might help at all. All the other monitors have completed several times during other drive cycles. All I want to do is pass the smog check so I can renew the registration and sell the van. Thanks for all the ideas.
Old Feb 15, 2023 | 04:35 PM
  #36
aquanaut20's Avatar
OK, you have 12vdc on the power wire, did you also check the ground side ?
If the harness side is proven good, then the other option is the wire or heater in the sensor..
Old Feb 22, 2023 | 04:57 PM
  #37
diegob's Avatar
So I decided to buy new sensors. I replaced one first, no codes but no dice. I replaced the second and that finally did it. I guess they were just old. Thanks everyone for the help.
Old Feb 22, 2023 | 11:33 PM
  #38
aquanaut20's Avatar
Glad you have a resolution, as a point of interest, did you check the continuity of the heaters in the removed sensors.?
Old Jul 30, 2025 | 10:26 AM
  #39
Troutbob's Avatar
I have the same problem . Any solution? No Code. Drive ready wont clear Heater circuit Voltage on OBD reader shows a line
Old Jul 30, 2025 | 02:00 PM
  #40
aquanaut20's Avatar
You need to confirm the power and ground at the sensors (2 common coloured wires)
wildernessbob
May 8, 2022 04:27 PM
2thou2tribute
Mar 23, 2022 02:54 PM
bradleyheathhays
Nov 23, 2020 05:30 AM
Chaseutb
Nov 6, 2016 07:13 PM
greuelc
Mar 6, 2009 10:30 PM
