E350 no spark, please help
Old Jun 27, 2017 | 12:13 AM
Dzasta's Avatar
Default E350 no spark, please help
Truck ran great, until one day it wouldn't start. Getting no spark from coil. Got 12 v to coil.. But not getting trigger signal on pin 2 from ICM. Replaced coil and ICM. Same problem. Cut and replaced #2 wire. Same problem. #6 pin from ICM gets signal.. Which I believe is the pip or hall effect sensor from distributor.. So it can't be that?? Why am I getting no trigger? I can manually create spark on all cylinders with jumper wire to trigger wire. Bad ICM still? Original tested good.. And bought ne
w one... Same issue.. No trigger.. Possibly bad pcm? Please help before I turn this truck into a target practice object. Thanks!
Old Jun 27, 2017 | 12:32 AM
Dzasta's Avatar
BTW vehicle is 1992 econoline e350 with 5.8 and gray push start remote mounted module
Old Jul 1, 2017 | 07:06 AM
It would not be the first time a "new" part was defective.
Have had several where the roll pin for the dist gear sheared and spark was either to wrong cyl or no spark at all.
Check if the rotor is turning and aligns the timing mark on the crank pulley with the rotor pointing to #1 spark plug wire.
Also, confirm continuity of pick-up coil in dist. Sometimes those wires break.
Billy62
Mar 31, 2014 05:08 PM
JCtrayer
Nov 22, 2011 10:07 AM
JCtrayer
Oct 28, 2011 05:32 PM
Rogerseric
Aug 12, 2011 12:34 PM
67comet
Jan 1, 2007 02:47 AM
