HELP! Intermittent PCM fuse blowing
Old Oct 26, 2019 | 10:08 AM
Brent Church's Avatar
Default HELP! Intermittent PCM fuse blowing
My 99 E150 4.6 work van randomly blows the PCM fuse. I can drive it for 50 miles sometimes and it will blow the fuse and keep blowing it until it sits for a while then starts right back up. It even has blow before and I replaced the fuse and it starts right up and drives another 50 miles. I've disconnected just about everything I could while it was blowing the fuse and found nothing. I've pulled the fuse box apart and it looks fine.
Any help would be appreciated as this van is how I make a living.
I need the wiring diagram for the PCM circuit. I bought the Haynes manual but as usual they're no help.
Old Oct 26, 2019 | 08:31 PM
Welcome to the site.
Theres actually 2 fuses that supply power distribution for the PCM power relay function.
Is it the 30 amp in the Battery Junction Box ? or the 30 amp in the Central Junction Box that blows?
Old Mar 8, 2023 | 01:12 PM
Virussuriv's Avatar
I had the same issue with my e 250 and it was a ground issue on the o2 sensor grounding it's self on the engine block just before it exits the main wire bundle. Once we fixed that the issue stopped completely. When you take off the dog house it will be the aqua connector close to the driver side. Check that entire area because it rides against a bolt head that is the culprit.
Elijah Earl
Jan 14, 2020 11:04 PM
Muhammad Jamil
Jul 17, 2017 05:33 PM
Alex Helms
May 8, 2017 01:21 PM
monkycrew
Oct 29, 2012 06:54 PM
1997 blue expedition
Dec 12, 2006 01:02 PM
