Leaf Spring Hanger, front/forward mounting position
Old Nov 8, 2018 | 06:29 PM
phucvannguyen's Avatar
Default Leaf Spring Hanger, front/forward mounting position
I am looking for front/forward mounting leaf spring hanger for my 1997 E-150 conversion van, XL, V8, 4.6L.
Does anyone know where I can locate/find this parts, new or used
Thanks.
Old Nov 9, 2018 | 02:54 AM
For new, you might try , "Vintage Parts Inc.
Beaver Dam, Wisc.
Used your best bet is probably a salvage yard.
I am not sure if the hangers were bolted or riveted to the frame. In either case they may use special type shoulder bolts when replaced . Unless ordinary grade 8 bolts are a snug fit , it could allow them to get loose. If new are available it might be a good idea to inquire about the correct retainer bolts and get them if available.
One other place you might check is a spring repair shop, they usually do these jobs pretty frequently.
Old Nov 9, 2018 | 06:24 AM
This conversion van is in very good condition, entire family of 7 seat very comfortable. I replaced both front radius arms and all of front bushings, rearward lift spring hangers and brackets due to rust/corrosion, except forward hanger is discontinued by Ford and in need of replacement.
I bought a few hangers online but they don't fit due to either incorrect spring width or mounting holes are not correct. Fortunately, they are returnable.
Will try the places that you recommend and thanks four input.
Old Nov 9, 2018 | 10:10 AM
I am able to locate both of these front/forward mounting hangers from a local salvage yard with visual checking at them to make sure they are correct. Currently, the salvage yard is working to have them pulled.
Thanks Hanky for your input.
Dware212
Feb 28, 2020 06:49 AM
Jc Crist
Mar 25, 2017 01:19 PM
DwayneGT
Feb 25, 2011 12:03 PM
afordman
May 19, 2009 02:33 PM
rootercycles
Nov 6, 2008 08:24 AM
