Loud clanking noise on startup
Old May 17, 2023 | 02:34 PM
  #11
Two things,
Noises have a way of telegraphing thru the vehicle and don't necessarily always make sense as to where they originate.Dampener problem most likely would not go away after warm up.
Can you create the noise when the vehicle is not moving and you briefly apply some throttle while in gear with the brakes on?
If so it could be a broken motor mount allowing the moving parts to contact something that may be close by.
Old May 17, 2023 | 05:41 PM
  #12
Ajcrain06's Avatar
Two things,
Yeah you could do that and the noise would be there. But wouldnt the motor mount also make the noise constantly?
Old May 18, 2023 | 11:59 AM
  #13
No ! When throttle is applied the engine attempts to apply power and will lift some as power is applied until the torque is reduced.
If a mount is bad , you will see the engine lift and look like it wants to come out of the engine compartment. Depending on the degree of wear, a faulty mount can produce a lot of different symptoms.
Old May 18, 2023 | 12:07 PM
  #14
Ajcrain06's Avatar
Ok, I’ll check mounts. The thing that stumps me is that the noise goes away after a little driving? I don’t think the expansion of the motor due to heat would be enough to fill the space in the worn mounts?
Old May 19, 2023 | 01:04 AM
  #15
ShawnK2017's Avatar
Will look at it tomorrow, Thanks
Old May 19, 2023 | 01:07 AM
  #16
ShawnK2017's Avatar
Hi Guys, Please look at my post here : I have the same issue
https://www.fordforum.com/forum/ford...d-noise-47163/
bpowell
Mar 14, 2023 10:40 AM
Brickster11
Jul 13, 2022 03:18 AM
zombieoverlord
Jul 10, 2022 03:28 PM
alexanderjclute
Apr 7, 2017 08:28 AM
mathew816
Nov 9, 2008 02:42 PM
