Negative Arc platform springs??
Old Feb 4, 2025 | 04:01 PM
BigJC's Avatar
Default Negative Arc platform springs??
I would love to improve my van's handling on washboard. I air down, have aftermarket shocks etc., but I only just discovered the idea of a negative arc spring to replace the flat load spring on the rear leaf's.
Specifically these one's made by weldtec
https://weldtecdesigns.com/product/wtd-ford-e-series-negative-arc-platform-spring-pair/?srsltid=AfmBOoropk2ZgvXuLQCCd5OkJ2XdQ35Z3BVKzCb8
Mainly, I'm just curious if they're worth the effort and if they would make a difference...to their claims?
Anybody have experience with these or just removing the platform spring or ideas etc? I'm all ears, thanks
Old Feb 5, 2025 | 03:35 PM
BigJC's Avatar
If these were installed wouldn't that create a problem with the spring shackles ?
How?.
Old Feb 5, 2025 | 06:17 PM
BigJC's Avatar
Look at where the shackles go with your present suspension. Where would they go with reversed arced springs ?
Could the springs hit the hangers ?
It's just the bottom spring. It's about 18 to 24 in or something. It's not even clamped into the leaf spring stack. There are helper springs that engage the shackles that you would typically clamp in under the support spring, but that's not what I'm speaking to here.
Best I can tell most custom and aftermarket leaf spring stacks come with a reverse Arc support spring versus a flat one.
Old Feb 6, 2025 | 08:57 AM
BigJC's Avatar
Everybody's suspension contacts the flat helper spring. It's only a half inch off the leaf at static ride height.
Old Feb 6, 2025 | 10:08 AM
You might consider getting another opinion, but this time from a spring shop. They deal with springs and suspension every day.
Uno
Oct 23, 2022 07:59 PM
d.rich
Oct 10, 2014 12:23 PM
2002 crownvic
Apr 29, 2013 07:30 AM
585jim0
Apr 3, 2011 09:14 AM
tennford
Mar 18, 2008 11:28 PM
