spacer for gear shift lever
Old Aug 1, 2022 | 09:28 AM
furnacemanjoe's Avatar
Default spacer for gear shift lever
I have a 2008 e 250 econoline 5.4. When I went to change the steering shaft bushings, I found the piece that secures the shift lever to the housing broken into two pieces. Looks like a wedge made out of pot metal. Ford can't find a part # for it. Any help would be appreciated. Thanks
Old Aug 1, 2022 | 09:36 AM
If you can, your best bet here is to consider a salvage yard. Take the tools you will need and they may let you take only the parts you need, some will not allow that and require you to take the upper strg column. All places are different.
If you have the time to shop around you might get lucky and find that original part.
Old Aug 1, 2022 | 04:50 PM
Thanks for the advice
Old Aug 2, 2022 | 04:08 AM
raski's Avatar
Check out this site to locate another similiar vehicle in a boneyard close to your location.
www.car-parts.com
crmale4u50
Apr 23, 2018 06:10 AM
Adeline Jackson
Sep 20, 2017 06:38 PM
Steveromo
Oct 24, 2012 08:25 AM
Yapalot
Apr 26, 2011 05:29 PM
stubbie
Feb 11, 2011 01:13 AM
