Where is the blower motor resistor!?!
Old Feb 18, 2025 | 07:16 PM
Cbrownwho's Avatar
Default Where is the blower motor resistor!?!
Hello! I have a 1990 E350 with a 7.5 liter engine. Everything runs great minus the front blower. The a/c & heater work and the rear blower works fine but the front is a no go. The blower was intermittently working but has now completely stopped and won’t turn on. I have replaced the controls for fan speeds, the blower motor relay, but still no change. I need some ideas on what else to check or replace and I have no idea where the resistor is. Any help would be fabulous thank you!
Old Feb 19, 2025 | 05:31 AM
The problem is not with the resistor. The blower motor needs to be replaced.
Old Feb 19, 2025 | 07:23 AM
dpboone's Avatar
Default Blower Motor
I agree 100%. I have a 2006 E150 Chateau and have replaced the blower motor twice. Go online and find a Motorcraft unit. They will last 2x as long as Dorman or other aftermarket units. This is a simple repair as the blower is mounted on the firewall in the engine bay.
Old Feb 19, 2025 | 12:58 PM
Just remove the blow motor and do a bench test, only 2 wires, one is positive and the other is negative.
If the bench test result is good, reply back then I can submit diagrams for you to follow up what to check next.
Old Feb 19, 2025 | 02:48 PM
Cbrownwho's Avatar
Default Found the problem
There is a fuse link in the wiring and it was that! Thank you all for the advice and I’ll know when the blower actually goes out to just buy the blower 👍🏼
Old Feb 19, 2025 | 03:41 PM
Fusible links don't open just for the fun of it.. Something is drawing more current then that the link was rated for Keep an eye on it because it WILL happen again.
The most likely cause is the blower motor becoming difficult to rotate, pulling more current and exceeding the capacity of the link.
If there was a fuse instead of the link, it would blow much sooner.
Thank you for the update..
deano
Aug 22, 2011 11:46 AM
Warhawk68
Aug 11, 2011 02:41 PM
stangs400
Oct 31, 2007 02:51 PM
PJMZ28
Aug 10, 2007 09:23 PM
David Mason
May 27, 2006 08:20 PM
