2002 ford escape xlt
Old Apr 11, 2021 | 01:07 PM
Donny Sawinski's Avatar
Default 2002 ford escape xlt
Hello, I am having trouble figuring out my issue here. Maybe someone can help. I have replaced wheel bearings on both sides in front, even new hub assembly. I have also replaced the cv axle on both sides. I have rotated my wheels, I still have a loud humming or grinding noise on the driver side front. I am at a loss here.
Old Apr 11, 2021 | 02:45 PM
scott.butler4's Avatar
Check if the wheel weights on the rim are hitting the caliper. There is minimum clearance between the front calipers and rims so you cannot use sticky wheel weights.
Also check your brake backing plates are not hitting the rotor
Old Apr 11, 2021 | 03:18 PM
Thanks a lot for your feedback. I will take a look at that
Hiedi Wallenmeyer
Dec 14, 2019 08:30 AM
Fscott
Oct 20, 2017 04:05 PM
soopacee
Nov 8, 2016 12:34 PM
ExplorerFailing
Jun 8, 2009 12:43 PM
bigblockgt
Jul 5, 2006 06:42 PM
