2005 Escape V6 3.0 rough idle and stall
Old Jul 7, 2022 | 11:33 AM
tcave44's Avatar
Default 2005 Escape V6 3.0 rough idle and stall
Hi all - My 2005 Escape V6 3.0 with about 120k miles had a rough idle - dipping and recovering and stalling once in a while. Took it to a mechanic and he said the Mass Air Flow is bad and that it has a misfire on a couple cylinders. MAF is about $400 to replace. He recommended changing all the ignition coils and spark plugs and wants over $1100 for that. Is that an acceptable price? Seems crazy to me but haven't had this before. Having him do just the MAF right now and holding off on the big one until I figure out if that's normal. Any thoughts on the diagnosis and pricing? Thanks in advance.
Old Jul 7, 2022 | 11:38 AM
raski's Avatar
That $$ seems high to me. I would stop by one of the big chain auto parts stores, have them connect a code scanner to your vehicle. Write down all codes which may be present and let us know what they are. I would hold off all parts replacements till we see what codes are present. Makes no sense to do a partial repair right now.
Old Jul 7, 2022 | 11:41 AM
tcave44's Avatar
I have a basic scanner and checked codes before I brought it in. P0172 (too rich - bank 1) and P0175 (too rich - bank 2). Curious to see what codes will still exist after doing just the MAF today.
Old Jul 7, 2022 | 11:48 AM
raski's Avatar
I would try cleaning the MAF sensor with the appropriate cleaner before replacing. You got nothing to lose if you are having it replaced.
Old Sep 14, 2022 | 03:06 PM
Deliveryguy's Avatar
Paid 68 bucks for my MAF sensor replacement off Amazon. Took literally 15 seconds on my 2009 3L Escape to change it, likely the easiest sensor in the engine to change out. Check also the throttle body and gasket, <$100 4 bolts and two clamps to undo to change it
Daniel Lindsey
Apr 28, 2021 08:45 AM
joejoebo
Dec 13, 2014 01:24 PM
alfamarvin
Nov 12, 2012 10:27 PM
iuecbrad
Jul 7, 2012 09:34 AM
onthefence
Jan 23, 2011 10:22 AM
