2008 Escape - Front Left Turn Signal Not Working
Hi Everyone,
Trying to get my Escape through inspection and the only thing wrong with it is the front left
turn signal light does not blink. When I turn it on, the left indicator blinks very fast. This
started after a deer hit left a crack in the headlight lens and it filled with water prior to me
getting the car. It also does not blink when the emergency flashers are on. Every other works.
So far I have replaced the entire assembly, bulb, relays, and turn signal switch
on the column. Checked all connectors and looked for broken . There is definitely no
power going to the left side socket, checked back as far as I could (goes the the fender well).
The wire is blue w/ green tracer. However, i can not find anywhere that color goes through
the firewall, and so far no luck on finding a wiring diagram.
Any help would be GREATLY appreciated.
Thank you,
Jim
Thank you,
Jim
polarglock
Aug 23, 2011 08:50 PM
tylyn
Dec 5, 2010 09:46 AM
