Left turn signal light problem
Old Jan 9, 2009 | 06:45 PM
Fizgig's Avatar
Default Left turn signal light problem
[&:]Hi all,
I have a 1993 Ford taurus, it has developed a left turn signal light problem, it signals very rapidly, is thare a light bulb or fuse problem?
Old Jan 9, 2009 | 09:33 PM
Sterling_Six's Avatar
Default RE: Left turn signal light problem
ORIGINAL: Fizgig
[&:]Hi all,
Hello and good day:
Just a few question first.
1. It's just the LEFT turn??
2. Have you check'd the lights out side as they are Blinking??
3. Has this just start'd or has it happen before??
4. How long have you had this car??
Usally if the Light is burned out the Turn Singnal will stay soild color, on the dash panel...If the fuses have blown your Light will not come on at all
Good luck and keep us advise.
Old Jan 10, 2009 | 11:09 AM
way2old's Avatar
As Six stated, look to see if there are any outside lkight bulbs blown. Fast flashing usually is a blown bulb. If all bulobs are good, then we need to go deeper.
Old Dec 2, 2011 | 07:32 PM
limonada's Avatar
Default I have the exact same problem
Hi All,
I have a Ford Taurus GL (1995) and I have the exact same problem. Two weeks ago the left turn signal started blinking very rapidly and the rear signal light is not working, although the light bulb is not burned (I even tried it with a spare bulb).
It's the first time this happens to me. Does anyone have any idea where the problem could be? Thanks.
Glowbug
Jan 28, 2022 12:43 PM
kmerritt
Oct 31, 2012 10:06 PM
polarglock
Aug 23, 2011 08:50 PM
Geoff Dow
Mar 7, 2009 06:34 AM
bud121156
Jun 27, 2007 12:10 PM
