2008 Ford Escape key issues
Old Sep 8, 2023 | 12:19 PM
Jhunty94's Avatar
Default 2008 Ford Escape key issues
Hello,
Having some issues with the key for my 2008 ford escape. The remote signals from the key fob no longer work. I have tried changing the key battery, disconnecting and reconnecting the battery but neither have worked. It's a relatively new battery 3-4 months old so that's not the issue.
Also the physical key won't open the door so i can no longer lock the vehicle.
Has anyone had similar experiences and successfully fixed the problem ? Even if I could get the physical key working I could lock the vehicle internally. I read online that it might be something to do with the code panel on the side of the vehicle.
Any help would be appreciated!
Old Sep 8, 2023 | 12:49 PM
Until we check and know for sure, what is the door lock assy on the driver's door doing? If it is in a possible half way position or hanging up due to lack of lubrication?
Until we know that we can't move on to why it may or may not be responding to the proper signals .
Old Sep 8, 2023 | 01:04 PM
Jhunty94's Avatar
Thanks for the response. The car locks with the manual lock button inside the vehicle so I don't think the physical lock is the issue.
Old Sep 9, 2023 | 08:06 AM
Keep in mind that when you move the part manually , there is a big difference from the solenoid having to move it.
Tupelosue
Nov 4, 2023 06:11 PM
posam1950
Nov 15, 2021 06:14 PM
Pk64f100
Aug 6, 2018 01:55 PM
arkansas-bigfoot
Apr 4, 2013 07:09 PM
