2011 escape xlt 2.5 liter
Old Jul 31, 2018 | 12:24 PM
Randy Dunsmore's Avatar
Default 2011 escape xlt 2.5 liter
I bought this thing a few months ago with lots of issues..I started by replacing spark plugs and coils..it ran somewhat better..changed EGR valve..no change..changed cam pos sensor..minor improvement..changed crank sensor..minor improvement.
But the main problem is still there so I haven't found the problem yet. when driving on the highway it'll go from running pretty much perfect..to all of a sudden running like it's off of its timing. .to get the vehicle to speed up when it like that requires way more gas peddle than it did before..then just as suddenly it will run near perfect again.
each of the switching from good to bad and back to good again can sometimes take less than a minute. and then other times it'll run at 110 km per hour perfectly until I slow down 10 or 20 km per hour and then switches back and forth as stated above.
What the hell is the problem? PCM?? Help!!
Old Jul 31, 2018 | 01:14 PM
Sometimes there could be a problem and it may not lite the check engine light.
However, there might be a code in the computer, which if there is could give us a little guidance.
Places like Autozone will check for any codes and do it for free, Can you do that?
Old Jul 31, 2018 | 01:20 PM
the only codes I get are 0301 0302 miss fire codes on mostly the first and second cylinders now..at first it was on all four cylinders
Old Aug 3, 2018 | 10:03 AM
09XSCAPE's Avatar
spark plug wires could be intermittent
have you monitored fuel pressure when this misfire occurs?
Old Aug 3, 2018 | 10:42 AM
Hi..this model has coils on top of the plugs..I'll check the fuel pressure next..I'm going to check the throttle body..I think this may be the problem..
Old Aug 3, 2018 | 11:29 AM
09XSCAPE's Avatar
IIRC Escape, not sure what years, had issues with TB. There was a TSB for it.
Yeh brain fart....coil on plug. coffee hadn't kicked in yet
rockauto likely best $ on TB if that is it
0301,0302 would typically be cyl 1&2misfire...but when car is stumbling for whatever reason (say low FP for example) the car "misfires" because of the low FP, not that there is a ignition issue with cyl 1&2 but the stumble is seen by PCM which references what cyl misfired as a result of the low fuel pressure induced stumble
A FP check would rule in/out a fuel issue. You already replaced coils & plugs so things like TB.....or MAF (try cleaning MAF) could be the issue
Old Aug 3, 2018 | 11:31 AM
thanks I'll try that
Old Aug 4, 2018 | 10:14 AM
Greg Lewis's Avatar
It's the throttle body in which Ford will cover the cost. Was not an official recall but one less than that. Look it up on Ford website.
Good luck
Old Aug 4, 2018 | 12:58 PM
09XSCAPE's Avatar
yep...google brought up several posts about defective TB's. Not sure what, if any, mileage or age to get Ford to fix for free
Search for TSB on it (technical service bulletin)...not a recall but is what a dealership would use to replace it at Fords exspense
ksbs
Mar 9, 2020 12:56 PM
chris2011
Jun 13, 2019 10:25 AM
Loren Slater Jr.
Feb 19, 2018 08:10 AM
mikebruce700000
Sep 14, 2016 10:45 PM
James Brandon Stitzel
Feb 12, 2013 04:24 PM
