2014 Escape 2.0L Ecoboost Engine Replacement
Old May 11, 2022 | 10:19 AM
jimball2112's Avatar
Default 2014 Escape 2.0L Ecoboost Engine Replacement
Question, I have a 2014 Escape with the 2.0L engine, with 113,000 Miles. Have all the usual suspects, P0300, 301..., Loss of coolant, white smoke on startup. I know what the problem is, and the remedy. Engine Replacement. My question is what is the best route to go. Looking for options, but Ford Parts availability is non-existent. Should I go used, and can I go with a newer model engine (2018+), or do I have to stick with my model year? I've also looked into ATK reman engines, but not to sure on those.
What things should I be looking for in used or reman? What is the concensus remedy beyond being able to be covered under warranty, which I obviously cannot. I'm going to put an engine regardless. It will have a rebuilt transmission and engine replacement within the last year. If I can get some decent life out of it, I'll drive it till the wheels fall off.
Old May 12, 2022 | 06:38 AM
Sometimes the cheapest is not the best.
If you know what caused the problem, just try to avoid walking into that problem again,,,,,,,,,,,,,if possible.
Mightykay19
Apr 14, 2022 11:26 AM
Mightykay19
Apr 11, 2022 08:36 PM
shanvhere
Jun 9, 2021 06:08 PM
awat9
Jan 10, 2018 11:05 PM
Coristewartrn
May 7, 2017 04:23 PM
