Ford Escape 2006, misfiring
Old Jan 30, 2019 | 08:12 PM
Bixwaltg's Avatar
Default Ford Escape 2006, misfiring
Hi all, I am new to this forum. I have a issue with my 2006 Ford Escape 3.0l XLT. The vehicle is misfiring with the battery light on the dashboard going off and on. The misfiring gets worst when the air condition is on. When I run my obd2 error checker and no error codes were found. I have change spark plugs but same results. Can someone please advice me on what is the possible problem and solution to my problem I would be very grateful. Thanks in advance.
Old Jan 31, 2019 | 12:46 PM
Diagnosing over the internet gets kinda risky.
Something you might check out,
To me it seems, there is a poor connection supplying power to the vehicle and its components.
First I would suggest that you check and make sure all the connections coming right off the battery going to the various parts of the vehicle are clean and making good contact. If any doubt, remove and make sure they are clean and tight. This includes all the ground connections too.
If that doesn't solve the problem unplug the plug from the alternator and see if that makes any difference with a short test drive. If it does, there is a problem with the alternator and it may require replacement.
Old Jan 31, 2019 | 01:04 PM
Bixwaltg's Avatar
Hanky, thanks alot. I will try what u suggested.
Walter
Old Feb 18, 2019 | 08:46 PM
Bixwaltg's Avatar
Default Engine miss
Hanky,
I tried what you told me to. The alternator sending out 4.2 volts, put new spark plugs
texgirl6969
Jul 22, 2019 06:24 PM
BackInTime
Aug 2, 2017 02:44 PM
truck crazy man
Dec 23, 2016 10:21 PM
Grnmstr
Oct 19, 2014 06:38 AM
elliemae
Oct 12, 2011 07:55 AM
