Need help.
Need help.
I was driving to work this morning and out of nowhere my car shut off. The radio kept playing and when I tried to start it again it doesn't even crank. I checked the fuses,battery,starter and alternater. Engine did not seize and it is not an anti-theft measure. I hooked up my scan tool and it won't connect. Any advice would be appreciated.
This could be caused by a shorted sensor problem.
What you might try is to unplug the various sensors, (throttle position, ABS, MAF, CTS, IAT, CKP, CMP, VSS (START WITH THESE) while watching your scan tool when you unplug the defective sensor you should see the tool begin to start communicating.Do one at a time and if no change plug it back together and go on to the next one.
BigRig Mechanic
02-26-2009 06:12 PM
