Need help.
Old Apr 20, 2018 | 12:48 PM
Frank turner's Avatar
Default Need help.
I was driving to work this morning and out of nowhere my car shut off. The radio kept playing and when I tried to start it again it doesn't even crank. I checked the fuses,battery,starter and alternater. Engine did not seize and it is not an anti-theft measure. I hooked up my scan tool and it won't connect. Any advice would be appreciated.
Old Apr 20, 2018 | 12:55 PM
It would help if we knew what you are driving ie. year,model, engine etc.
Exactly what does your scan do or show? Any display?
Old Apr 20, 2018 | 01:16 PM
03 ford escape 6 cylinder. The scanner comes up with a link error. When I looked into it I found that it means my cars computer isn't communicating properly or not at all.
Old Apr 20, 2018 | 02:22 PM
This could be caused by a shorted sensor problem.
What you might try is to unplug the various sensors, (throttle position, ABS, MAF, CTS, IAT, CKP, CMP, VSS (START WITH THESE) while watching your scan tool when you unplug the defective sensor you should see the tool begin to start communicating.Do one at a time and if no change plug it back together and go on to the next one.
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
BigRig Mechanic
Feb 26, 2009 06:12 PM
streetbob
Jun 17, 2008 05:01 PM
Adhd
Feb 3, 2008 09:55 PM
