1997 Escort Throttle Hesitation
Old Oct 8, 2017 | 11:09 AM
Mike Mulback's Avatar
Default 1997 Escort Throttle Hesitation
Problems with a approx 10% throttle opening Seem like engine dos not know what to do. Hesitates Sometimes will die out then restart. No Codes Shop is clueless replaced 02 Sensor No diffrence
car has all preventive maintenance done already, Fuel pump timing belt crank position sensor ect. Help
Old Oct 8, 2017 | 02:03 PM
Need to know ,
Does it happen only when cold, hot ?
What about spark plugs , fuel filter, anybody check the throttle position sensor?
Why did they replace the o2 sensor?
May be time to find another shop.
Old Oct 8, 2017 | 10:08 PM
Happens Hot ( Warm )
New plugs filters ect.
Had a code for 02 sensor has been replaced.
Will try swapping in a Throttle position sensor. yes?
Yes Throw pep boys in the garbage
Old Oct 9, 2017 | 02:18 PM
I don't believe it is professional to poo poo another shop regardless of how questionable the work may be , but it is important to know when to get a second opinion especially when it costs $$ and the problem is not corrected.
Swapping parts can get expensive when guessing too!
With so many electronic components in vehicles these days it is better to check many things before jumping the gun. The question of asking about the throttle position sensor is only to suggest that it be checked. Diagnosing over the net is not always good thing to do. There must be another place that you can try to have the systems checked out. There are readings that a shop can take that could help reveal where there is a problem like eng temp, fuel trim, etc.,you just need to get to a good shop that will check these things.
Old Oct 9, 2017 | 02:56 PM
I do appreciate your input, Thats true not poo poo a professional shop unless the problem ect wasn't solved Whatever.
I thought that someone might have a similar problem that could give me direction. Alot of unsuspecting people get reamed daily at these shops.
Yes the car is running lean reason for 02 Code. and the fuel trims will tell let me know just how lean its running I get it. This testing is well beyond the limits is the mentioned poo poo Shop.
Funny thing I have the tech ll scanner in the garage- also another escort to swap parts from to not throw money at the problem.
Any other suggestions?
Vanessa Dallas
Apr 23, 2012 06:47 AM
WV-F150-4.2L
Mar 16, 2011 06:34 PM
notafordman
Mar 21, 2008 04:21 AM
jimw
Nov 20, 2007 06:38 AM
swamper8
Nov 14, 2005 05:03 PM
