1999 Ford Escort acceleration noise
Old Nov 6, 2010 | 06:10 PM
Edy Escort's Avatar
Default 1999 Ford Escort acceleration noise
Hello all, I have a 1999 Ford Escort with 120,000 miles which is making a strange noise: after 10 minutes of driving the car, I hear a rattling/whizzing sound when I try to accelerate-it lasts about 4-5 seconds and then goes away- I can drive with my foot on the gas pedal to about 40 mph but when I go over 45 miles per hour (press down on the gas pedal harder) I hear this noise...., the oil has been changed recently, air filter, etc.- I have no problem accelerating though (just the strange noise) and no service engine soon nor check engine light comes on... Anyone have any idea what might be going on? and any fixes to stop the noise?
Thanks,
Edy Escort
Old Nov 7, 2010 | 04:09 PM
One thing comes to mind (no room for more) ,is the air filter assy put back together correctly. Sometimes the filter assy will vibrate if parts are misaligned.
Old Nov 11, 2010 | 03:30 AM
mmurphy's Avatar
Thumbs down
Have you looked underneath, behind catalytic converter? I have something going on like that with some pretty odd vibrations that was coming from the heat shield coming loose off of pipe. Fix, reweld.
Old Nov 11, 2010 | 03:31 AM
mmurphy's Avatar
Thumbs down
Old Dec 7, 2010 | 09:57 PM
zx2_2001's Avatar
hi there, ive owned quite a few 3rd gen escorts and on a handfull of them i took notice that when you get a ratteling noise its usually the cat heat shields or the pipe heat sheilds (under the oil pan) or on the ends of the flex pipe the metal rings that protect where the braiding meets the pipe come loose and hang on the pipe causing a rattle. and to fix the 2 heat sheilds you can put a large hose clamp over the cat and 2 medium sized hose clamps on the sheilds under the oil pan and as for the flex pipe rings you can just cut them off or have them tack welded back on. hope this helps
-jim
Nrod
Aug 30, 2016 02:16 PM
Billy Bo Bob
Apr 12, 2013 09:08 AM
cyclonehank
Aug 22, 2011 06:45 PM
ajhamel
Apr 25, 2008 11:50 AM
machaons
Jul 12, 2007 06:39 PM
