1999 expedition 5.4
Old Feb 15, 2025 | 03:09 PM
Staren72's Avatar
Default 1999 expedition 5.4
A diagnostic said my fuel pump was going out. Had a mechanic replace pump and filter. It wouldn't start. Tried priming multiple times, still no start. Mechanic left with my repair manual to come back following weekend. No response. Took fuel filter off found very little gas in it. No idea how to check pressure but there's no hiss when I open fuel cap. All electrical stuff testing good. Have 7 gallon of gas in tank. Don't know what else to do. Please help
Old Feb 15, 2025 | 04:33 PM
Your vehicle has what is called a "Fuel Pump Driver Module". That module gets it's signal from a fuel pump pressure sensor mounted on the fuel rail.
If pressure is low it gets full power, as pressure comes up it is pulsed to maintain a specified pressure .
We don't at this time know if the sensor is faulty or maybe something else is going on.
A capable scan tool would provide all that info , like desired and actual fuel pressure..
Those modules were mounted on a chassis cross piece and were known for corroding where contacting the frame cross member and not working. REPLACING the driver module solved the problem.A new mounting prevented that part from corroding..
Old Feb 16, 2025 | 12:33 PM
Staren72's Avatar
What kind of scan tool is it and how do I use it?
Old Feb 16, 2025 | 02:53 PM
They go for a couple thousand $. you can get cheap ones, but they can't do too much.
Autel is a good one.
Old Feb 17, 2025 | 01:09 PM
Staren72's Avatar
For that price I should just take to shop lol. But I think I found the problem. When I took it back off, the ring was blown out. Replacing it now. Will see how it goes
Old Feb 17, 2025 | 02:56 PM
If you found the same "O" ring that was originally in there , great. .
If not , they are special fuel resistant material and regular ones won't last..
Old Feb 18, 2025 | 02:00 PM
Staren72's Avatar
Not the original one, but they did give me one from another box of same part. Put together, replace fuel lines, it started right up. Thank you for the help
Old Feb 18, 2025 | 02:12 PM
Thank You for the update.
T Miller 86
Apr 24, 2024 01:04 PM
Jtollett7717
Jul 13, 2023 06:46 PM
Rarta
Dec 10, 2012 01:54 PM
DennisSJ
Jul 30, 2009 10:30 AM
jinandtonic1234
Feb 8, 2009 03:37 PM
