2004 Expeition possible ECU problem
Old May 31, 2017 | 01:11 PM
ronkwilson's Avatar
Default 2004 Expeition possible ECU problem
My Expedition runs very erratically. Low to no power for acceleration. Occasional backfire when driven and erratic shifting. The MIL is not on and there are no OBD codes. The ECU # is 4L1A-12A650-NA. I can't find a local ECU repair facilityfor testing/repair. I'm considering obtaining a used ECU to try. What are the ramifications of doing this? Such as ignition key no longer working and non matching VIN? Also, does a replacement need to have the NA suffix? I've been directed to one with an RA sufix, but I don't know if that's critical. Any input would be appreciated.
Old May 31, 2017 | 02:04 PM
You would not believe the problems encountered if you switch an ECM without a scan tool to "Program it" these days.
For starters' anthi-theft system will prevent the vehicle from starting then if you try putting in the old PCM , that will no longer work either.
Have you considered checking the ECM/PCM plug connections for any corrosion ? Common problem especially if moisture/water got nearby.
fnulnu
Nov 2, 2009 01:37 PM
jch2122
Sep 14, 2008 07:43 PM
g2redgsr
Nov 18, 2007 04:51 PM
ghight
Oct 22, 2005 06:29 PM
