2005 fuse number 3 has a parasitic drain
Old Aug 11, 2022 | 03:48 PM
richard1967's Avatar
Default 2005 fuse number 3 has a parasitic drain
what's up yawl new here on the forum, 2005 Eddie Bauer I'm having a dead battery issue every morning, truck has new battery, alt putting out 14 volts so i did a a parasitic drain test 89amps so i started pulling fuses and got to #3 and the amps dropped to 40 . #3 fuse runs these
[Mirror Switch, Power Mirrors (Non-Memory), Driver Seat Switch (Memory), Memory Module (Logic Power
so i disconnected Mirror Switch ,Driver seat Switch (Memory),all plugs under driver seat, and still 89amps draw, i did not disconnect the
power mirrors in each door, they are memory, {should i pull power to them also,} any other idea's thanks ,
Old Aug 11, 2022 | 05:18 PM
Hi Richard,
There are a few questions .
Are you sure the drain is 89 amps? That like 3 cars with the headlamps on hi beam and could hardly be called a parasitic drain.
Did you have an opportunity to look in your owner's manual for what the fuses protect? That info is in there.
Smooth
Feb 21, 2020 09:18 AM
Stormchaser
Jun 16, 2017 07:32 AM
saemetric
Jan 8, 2017 11:34 AM
spuccetti
Sep 29, 2012 12:46 PM
martinmroy
Nov 12, 2008 12:11 PM
