Catalytic converter
Old Jul 1, 2024 | 04:09 PM
Plmusso1's Avatar
Default Catalytic converter
2021 Expedition with 39400 miles needs a new left catalytic converter. Vehicle runs very well. This is my first car in 50 years that needed a cc replacement.
Is Ford having issues with quality?
Old Jul 1, 2024 | 04:45 PM
Why you need a new cat converter?
Is it under powertrain warranty still?
Old Jul 2, 2024 | 04:03 AM
Most times there is a reason for a converter going south.
Heiko brought up a good point, there should be some warranty coverage on that.
If the cause of the converter is not determined and corrected, it will destroy the new also,,IF IT IS REALLY DEFECTIVE.
Old Jul 2, 2024 | 06:18 PM
Plmusso1's Avatar
Default Catalytic converter replacement
It is covered under the 5yr/60,000 mile powertrain. The dealership was happy to replace it but no reason for it failing was given. I'm hoping they will check on that.
Of note the check engine light for code 0430 came on a few hours after the oil was changed.
Old Jul 5, 2024 | 06:30 AM
If the person doing the oil cge hit the wire for the O2 sensor there, it could be related.
Old Jul 5, 2024 | 03:17 PM
Plmusso1's Avatar
Default O2 sensor
Should the o2 sensor be changed with the catalytic converter? I believe it's 2 separate parts.
Old Jul 5, 2024 | 04:26 PM
I asked this previously above: Why you need a new cat converter?
I can answer my own question for you now. It's solely based on getting P0430 code.
If you or they don't find out the root cause, you are going to have to replace your cat every year at your own expense, if you think replacing the cat or the o2 sensor will fix P0430 permanently. The cat might be bad, but guarantee can't be the root cause, there must be some other issues to go along with it for it to go bad.
hanky already mentioned the issue could be caused by whoever changed your motor oil, he must have done something intentionally or negligently to your car, you just have to go back there and pretend to blame them and just to see what they say and don't mention about dealership/warranty. You just have to find out what else they have done beside changing the oil. They might have removed your o2 sensor for inspection but didn't put it back correctly.
Old Jul 6, 2024 | 04:32 PM
Plmusso1's Avatar
Default Cat
I have confronted them about why it happened on my way home from the oil change. They reported it was just a catalytic failure coincidence. I'll discuss this with them further.
Thank you for your input.
JeffTheGreat
May 19, 2023 01:28 PM
zusis
Oct 24, 2015 03:22 PM
FordExpGirl22
Mar 11, 2012 10:47 PM
kmestep
Dec 17, 2010 06:47 PM
erwisneski
Aug 23, 2007 01:57 AM
