Engine Surging
Old Sep 21, 2021 | 02:06 PM
Chambr's Avatar
Default Engine Surging
Afternoon ,,,
I am at my wits end trying to fix this issue ...
2003 Expedition 4.6L
Engine surges at idle (ill attach a video) ... replaced the MAF, Air Temp sensor, the Idle Solenoid and the PCV valve and hose ends ... still surges.
Thoughts?
File Type: avi
Old Sep 21, 2021 | 08:47 PM
You know this is shooting in the dark, right?
EGR system should be checked out, and so should the O2 sensors.
Don't get caught up throwing parts at it because that can get expensive and disappointing.
Old Sep 22, 2021 | 07:42 AM
Chambr's Avatar
Yep .. hence this post --- wanted to see if anyone else experienced this issue and knew of a fix ...
OBD reader doesnt pick up any codes wither which I would have thought it would..
Thanks
-Mike-
Old Sep 25, 2021 | 11:46 PM
dmckenzie's Avatar
I've had that happen to me when i done an intake on a 4.0 i believe. it was idle chasing because there was a vaccum leak after the idle air control valve. you'll have to do a smoke test or check vaccum connections
vmkrampitz
Oct 10, 2021 10:45 PM
besel53
Oct 6, 2021 10:58 AM
k64bc2003
Jul 2, 2010 01:18 AM
scfordowner
Oct 24, 2008 07:57 AM
Loum12
Mar 24, 2005 03:28 PM
