Heat problem
Old Nov 26, 2007 | 09:37 AM
bart0537's Avatar
Default Heat problem
I still need help with the heater problem. A 99 exp. that blows cold air and rear unit works fine. Does anyone know where the blend door actuator is located? Are there any heater components under the hood that might cause this problem? Thanks, Bart
Old Dec 1, 2007 | 11:10 AM
oldtimer35's Avatar
Default RE: Heat problem
It is located on the bottom of the air distribution box. You will have to remove the floor vents for the heater and then on the passenger side of the driveshaft tunnel you will see a box about the size of a cigarette pack.
Use Common Sense
Jun 25, 2016 01:30 PM
sk8dad
Jan 19, 2009 01:25 PM
TrentnSteph
Dec 12, 2008 06:46 PM
crownvicman90
Feb 28, 2008 03:00 AM
zcostilla
Dec 10, 2007 07:02 PM
