Need your help no Heat in front
Old Jan 6, 2018 | 04:11 PM
Firepuppy's Avatar
Default Need your help no Heat in front
I have a 2002 expo i have no heat in front but i have slight heat in back i have replaced thermostat, flushed heater core and still no heat so i figured blend door is open so instead of tearing out dash i cut the heater box cause the truck is old and ready for junk yard i cut the hole and closed the blend door figuring that would give me heat but no heat it almost feels like the ac is on why wouldnt i get any heat by closing the blend door Both heater hoses are hot to the touch
Old Jan 6, 2018 | 04:52 PM
When both heater hoses are the same temp it generally means the core is plugged. Flushing doesn't always clean out accumulated junk and replacement is the only cure.
tattooed_drew
Apr 6, 2020 10:59 AM
cve
Mar 8, 2017 06:15 PM
Use Common Sense
Jun 25, 2016 01:30 PM
MeMaintain
Apr 15, 2013 09:21 PM
Budsjlm
Dec 4, 2009 10:34 AM
