New 2003 Expedition Owner - Questions
Old Nov 2, 2021 | 02:22 PM
synapse888's Avatar
Default New 2003 Expedition Owner - Questions
Hi, I recently purchased a 2003 Expy Eddie Bauer 4X4 and couldn't be happier with my purchase. It has 171k miles. It has mostly sat for the last two years, but runs and drives fine.
I do have some questions etc
1 - I would like to order some touch up paint. Color code is E9 which is laser red metallic, but I can't figure out what the color code for the silver stuff on lower part of the vehicle. Anybody know that code?
2 - I would quickly like to make it sound better/deeper (but not loud just to be loud). I've read through a few threads and it seems like a new flowmaster muffler might be the play here? I've listened to a bunch of youytube videos of like the 40 a 44? and a 50? Any general recommendations (or links to threads I might have missed) that can make my expy sound better? Was figuring I would get a K&N intake as that appears to make it sound better too? And
3 - When I shift into reverse, I get the message "Check Backup Aid"...which I assume means the backup sensors aren't working correctly? Any ideas on how to resolve that?
4 - The third row seating switches don't do anything (seats stuck are down). Hoping that's a fuse...but haven't looked into it yet. Not a big deal anyway because they would mostly be down for cargo.
5 - I think it would be cool to replace the interior light assemblies with something more modern/(to get rid of the yellow toned lighting). Not sure if they make such a thing but figure this is the place to ask.
6 - Is there a thread or something that covers exterior mods people have done?
7 - The AC doesn't work, but assuming that's not something simple I could look into, I will end up paying someone to make it work.
8 - I am going to put in a new stereo and subs but probably don't need your fine folks' guidance with that one.
9 - The top position of the steering wheel is pretty funky/overly worn. Guess finding a replacement is the approach for that one?
10 - Is there a go-to magnetic cell phone mount around these parts?
11 - Only came with one key, what is the best way to get an additional one made?
12 - If I wanted to search for parts for this is there like a platform code or something I should be using? I have a VW Golf R, and that platform is known MQB. Is there something similar for these vehicles (knowing they share lots with an F150, is it?)
13 - What type of replacement wheels should I look for...is it like by bolt pattern or something?
***Big/most important item for last***
14 - I think this vehicle was pretty well maintained, but what maintenance items should I tackle...given the vintage, miles, and the fact that it hasn't seen much use the last two years. I'm sure there will be a lot so please prioritize the work [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img] (it has a brand new brake line as the old one rusted out)
I'm excited to join this community and thank you so much for any advice any guidance!!
Old Nov 3, 2021 | 09:12 AM
Before the "stuff" hits the fan,
your best bet is to go to a certified locksmith or Ford dealer or a shop with the info and equip to code a key for you.
If for any reason the only key you have stops working , then you have no choice but to pay for road service to have one of the above come to code the key to your vehicle.
Suggest you have at least 2 new keys made and coded to your vehicle.
With 2 working keys you can code up to 8 keys yourself after having them cut.
Keys sometimes stop working and the vehicle will not start. That is one reason for having another key that you know works.
Your vehicle has a PCM (Powertrain control module) that is coded to your vehicle with it's VIN. Special equip is needed and access to info if you do not have a working key to drive it to a place that can do the work.
Please consider getting this done ASAP.
herbert
Aug 21, 2012 09:07 PM
dj575
May 12, 2012 04:31 PM
SHONDARENE
Feb 22, 2012 07:37 AM
benalexe
Jun 6, 2011 05:58 AM
Henrock
Dec 18, 2006 12:02 AM
