New fuel pump installed mileage way down
Old Dec 17, 2019 | 12:58 PM
  #11
rog2867's Avatar
by any chance to know what the ohm reading would be for that model for full and empty?
Old Dec 17, 2019 | 01:26 PM
  #12
rog2867's Avatar
ok so they put a new fuel pump in so lets see if that makes a differenc.
Old Dec 26, 2019 | 11:48 AM
  #13
rog2867's Avatar
Ok, so they replaced the fuel pump and I filled the tank. Same issue gauge is off by little more than 1/4 tank. Since the sending unit if on the pump I imagine it can't be that. It only started happening after the pump was replaced the first time. What else can it be?
Old Dec 27, 2019 | 03:39 AM
  #14
One thing that could be done,
The repairing shop could remove the module and measure the distance the float has to travel in the tank and compare the readings at the gauge in the dash. The rod that holds the float can be adjusted to provide the correct reading for the empty and full positions.
Old Jan 9, 2020 | 12:15 PM
  #15
rog2867's Avatar
Ok so a few questions. I filled the tank a few times the gauge is off my a little more than 1/4 tank from what I can see. I watched a few videos about the removal and replacement of the pump. How do you adjust the float on the pump? I have not seen the actual pump but one would think it would come calibrated correctly if you order it by the VIN which they did. I am on the second pump now and have the same issue. Can you tell me how do you move the float lever itself up? I know it has to go up as i can see when the truck is being filled up the gauge hits F way before the gas pump at the station turns off.
Old Jan 9, 2020 | 06:33 PM
  #16
The gauge section and the fuel pump module are one unit, so the fuel pump module has to be removed or lifted out of the fuel tank in order to bend the float arm to position the wiper in the more correct position. If for instance the reading is hitting full before the tank is actually full, the float rod needs to be bent up so the position of the wiper that provides the reading level is lower. Very simple to do
. I cannot say that the rod might have been bent at the time of installation, but that does happen.
If the position is verified at the time the module is installed it saves all this trouble. As you know,,,,,,,all new parts don't always work perfectly when there is the possibility of something being altered on installation.
Old Jan 9, 2020 | 06:42 PM
  #17
rog2867's Avatar
got it, just wanted to know if there was any way to do it besides bending it. It has to go up as its showing empty when there is almost a half tank. This is the second pump doing the same thing, so I will tell them to bend it up slightly. thanks
Old Jan 9, 2020 | 07:06 PM
  #18
I hope you have good luck with passing on that info. I know you understand it, but after 2 times , I don't know !
Old Mar 9, 2020 | 02:56 PM
  #19
rog2867's Avatar
So the mechanic put an OEM pump in and the problem went away. Why 3 different after market pumps were not calibrated correctly is beyond me but that was what fixed the issue.
Old Mar 9, 2020 | 03:38 PM
  #20
Ouch !!
Not always, but there are reasons we suggest sticking with OEM parts.
lyoooha
May 2, 2014 10:04 AM
Kwakman
Jul 30, 2012 12:02 PM
Crawlerchris
Aug 2, 2008 05:59 PM
vioc34
Apr 20, 2007 03:25 AM
k9handler
May 20, 2005 03:05 PM
