1996 Ford explorer transmission problems
Old May 10, 2019 | 06:46 AM
fryguy's Avatar
Default 1996 Ford explorer transmission problems
The “o/d off” message began flashing on my dashboard. I did a computer check and got a PO 756 code and the solenoid #2 is in the off position. I went ahead and replaced all of the solenoids in the transmission but I still get the same code. Any suggestions on what I should do next?
Old May 13, 2019 | 03:12 AM
There are other possible things to check like the Park/neutral switch on the trans, trans control module and wiring to the trans.
Old May 21, 2019 | 08:59 PM
fryguy's Avatar
Default Things I’ve tried
I checked all the fuses associated with the trans and PCM. They’re all fine. No loose nor frayed wires in engine nor trans. I swapped out PCMs for a 1998 Ford Explorer but now it won’t start. I guess I’ll swap back for the old one. I haven’t tried the suggestions Hanky made yet since they all involve getting under and removing stuff and I’m a novice mechanic.
Old Jul 22, 2019 | 09:15 AM
fryguy's Avatar
Anyone happen to know if a transmission from a 2002 Mercury Mountaineer would fit my 1996 Ford Explorer?
Terry Long Sr.
Mar 8, 2020 12:46 PM
89gted
Aug 5, 2016 05:08 AM
Jeff
Sep 19, 2011 05:12 PM
mrwhipper
Dec 23, 2005 06:10 PM
mrwhipper
Apr 18, 2004 09:33 AM
