2003 Explorer 4.0 SOHC Upper Intake Removal Problem
Old Sep 9, 2018 | 09:33 AM
  #11
Originally Posted by Kenny James
I stripped out to of the torx bolts trying to get them out got 5 loose with no problem but stripped 2 out and cant seem to find the 8th one out. Also broke a torx bit as well theyre just really tight in therr has anyone else have this problem or suggestions???
What size torx were you using?
The most difficult bolt is the L/R under the cowl with limited access and visibility. If this is one of the stripped torx getting it out will be a challenge. This bolt only allows for about 6” extension or rise to allow for a ratchet because of the cowling.
Being they torque at 8 Lbs, unless corroded etc, they shouldn’t strip easily if the correct bit is being used.
That said, you may have luck driving the next size up bit into the head (difficult on the L/R because of access limits), or better yet with a rounded bolt extractor biting/cutting in on the outer diameter of the head. Possibly a mirror and an angle grinder to remove the head. Would be tricky though in that position, or any of the deep well positions. Visabilty is poor, access is bad.. Drilling the head off, possible, depending where or which one/s, but easy to damage the manifold.
A trick to remove stubborn bolts threaded into aluminum is to insert the driver, or socket with an extension where applicable and strike the head moderately prior to a removal attempt. Not always possible to do in access limiting positions though.
Can you give an account of exactly which ones are stripped?
Arron Lippincott
Jun 17, 2018 05:40 AM
timmytaurus
Dec 6, 2015 05:49 PM
Jmk321789
Jun 26, 2013 02:42 PM
jgood1985
Mar 17, 2011 08:44 PM
tsi18psi
Sep 27, 2007 07:48 PM
