2010 Explorer RWD will not crank
Old Jan 18, 2021 | 09:54 PM
Kenster's Avatar
Default 2010 Explorer RWD will not crank
Hello, Here's the situation, I have a 2010 Explorer Rear Wheel Drive. It used to start and now it doesn't even crank. Battery is good, with key in dash lights come on bells sound, turn key everything shuts off like the battery is dead. I got it to start just by trying neutral park back and forth then it started. Now nothing. So I removed the aftermarket remote start and anti theft unit. I made certain all wires were secure and as they were previously. Found one fuse which had blown, replaced it.
I need to mention that a lot of wires under the hood had been chewed apart by raccoons. I reattached them and made sure I got them all.
This is a rear wheel drive so the fuse layout is different than a 4wd. Even the manual is wrong.
I know how to test most components and I'm fairly computer savvy but I could use some direction here. Also key cylinder looks ok, shifter wouldn't go in park because of a pin issue but I fixed that,
Old Jan 19, 2021 | 12:54 AM
scott.butler4's Avatar
Which engine?
Old Jan 19, 2021 | 08:31 AM
Kenster's Avatar
Sorry, 4.0. I bought it with the wires chewed up After i fixed them it ran great.
Old Jan 19, 2021 | 04:39 PM
Kenster's Avatar
sorry 4.0 I should mention I bought it with the wires chewed up after I reconnected them it ran great.
Shane Judge
Jan 18, 2021 06:47 PM
Scooter Davis
Aug 1, 2017 11:09 PM
garcia16
Apr 24, 2017 09:55 AM
Jaym8282
Jul 22, 2014 01:19 PM
Eletraid
Jan 27, 2013 07:36 AM
