2013 Explorer Limited Climate Control
Old Jun 30, 2019 | 12:34 PM
SteelPride's Avatar
Default 2013 Explorer Limited Climate Control
I bought my 2013 Explorer Limited back in March. I believe its not working properly. I will try and describe the issue the best I can. Lets say that my current temp in my car is set on LO. If I want it to be warmer say around 75 degrees, it still is blowing cold air. If my current temp is set to HI and I want it to get colder say around 69 degrees, it still is blowing hot air. If I start at LO and what it warmer I basically have to turn it up to HI. If I start at HI and want it colder I have to turn it down to LO. There is no in between temps. Can anyone tell me what is wrong and how to fix it?
Old Jun 30, 2019 | 07:26 PM
There are various sensors in your vehicle that when you choose a particular setting it uses those sensors to attempt to respond to the request. There is a module that controls the actions , but it depends on correct feedback from those sensors. A capable scan tool should help pin down where the problem is originating.
I would be reasonably sure you would not want to have someone start switching parts hoping to hit the problem because that can get expensive. Might be a good idea to see if there any codes stored in the vehicle's memory. Places like Autozone can check your vehicle for any code, usually at no charge, but I don't know if that is convenient for you.
SteelPride
Jun 30, 2019 12:21 PM
Slumerican
Jul 19, 2015 10:45 AM
bmackinlay
Jun 5, 2014 01:47 PM
Morrow_d
Sep 22, 2013 04:37 PM
tbo3374
Jun 3, 2012 09:17 PM
