92 Ford Explorer air conditioner issues
Old Aug 22, 2017 | 07:11 PM
Kelly Barnes's Avatar
Default 92 Ford Explorer air conditioner issues
i have a 92 Ford Explorer sport, that the air won't work in! I've tried to put in two cans of freon to recharge the a/c but both times from both cans freon was not going in. The heat works just fine, no issues with it at all. But it's summer time and I'd like to see if it can be fixed without spending an arm and a leg. TIA!
Old Aug 22, 2017 | 07:48 PM
Hi Kelly,
Can you check to see if the air conditioner compressor clutch is operating. You should hear it click on when calling for AC. When it is working(energized) the center of the compressor should be turning with the pulley. I have to cover all these little things since I do not know your background with AC.
Old Aug 22, 2017 | 11:22 PM
Use Common Sense's Avatar
Has your A/C system been converted to R-134a refrigerant? If not, being a 1992, your refrigerant would be the R-12 type. Full fill of R-12 is 32 oz, with 7 oz. of paraffin oil. If your system hasn't been converted to R-134a, what type of refrigerant were you trying to put in. If your system was converted, you you know why and how long ago it was done? These all play into what may be the issue.
JDMAN1
Oct 9, 2023 06:50 AM
kctires
Aug 10, 2016 03:52 PM
stuartchamm
May 13, 2008 01:04 PM
kylesandi338
Sep 7, 2007 12:12 PM
JDMAN1
Jun 8, 2005 11:51 PM
