94 4wd
Old Dec 28, 2010 | 05:54 AM
dirtydognashville's Avatar
Default 94 4wd
The 4wd lights do not come on any more and does not seem to engage. Is this a new motor actuator or a more simple solution
Old Dec 28, 2010 | 12:38 PM
How about we check all the fuses first?
Old Jan 7, 2011 | 09:35 PM
The fuses were the first thing i checked. The 4wd low light was out when i bought it and it would only go into high. Then the hight light went out so no 4wd.
Old Jan 8, 2011 | 08:04 AM
This is what I would do.
Check at the switch to confirm voltage in and out.
Then check at the transfer case motor for the same voltage signals.
If the signal is present there , confirm a good ground connection at the motor.
If everything is right , recheck the motor itself.
hilliad
Jul 4, 2010 02:26 PM
mudpusher94
Jun 5, 2006 04:38 AM
jackson_turney
Nov 23, 2005 01:22 AM
hdvixen
Apr 29, 2005 07:37 PM
DYI
Mar 28, 2005 11:54 PM
