95 4.0L OHV cam position sensor location
Old Jun 16, 2019 | 11:48 AM
  #11
JustinWHT's Avatar
Default Pictures
I forgot to get pics last night. My bad
In drawing that Hayapower provided...(point of view - that would be looking towards the engine rear towards the driver side, towards sensor through the fender about even with top of right tire and next to firewall)...
The firewall is a few inches to the left.
On the right there is a hose or line running straight down to within a few inches of the sensor. Running your hand down that line, the sensor is below and to the center of engine.
The connector pulls off, I don't recall a clip you have to spread apart.
The sensor body will swivel about 20 degrees in either direction of center.
It's the only component in that area of engine that has a cable going to it.
/Added
He mentioned he had a '95 (First Generation). The only engine for that series was the 4.0 L OHV Cologne V6, which is what my '00 (Second Generation) has, so it should be the same.
Last edited by JustinWHT; Jun 16, 2019 at 12:04 PM. Reason: Point of view of drawing
Old Jun 16, 2019 | 12:33 PM
  #12
Petethecarguy's Avatar
Default Thanks cor your help
Presently , I removed pass side inner fender. Looking into the back of I don't see or feel the sensor. Now ji am going to remove the coil dip stick so I can get my hand in there from the top. Thanks again for your help.
Old Jun 16, 2019 | 03:47 PM
  #13
Default Still trying to locate CID
I used my camera and attached some pictures. Would you be able to mark them up to shown the location. still cant find it. there are 4 photos attached.
Mangus17
Aug 26, 2019 10:51 PM
jdshivers0613
Dec 10, 2016 09:42 AM
tsi18psi
Sep 27, 2007 07:48 PM
retread
Sep 8, 2005 05:03 PM
gmm
Jul 22, 2005 11:09 AM
