96 4.0
Old Jul 27, 2019 | 03:00 PM
TortugaSulcata1's Avatar
Default 96 4.0
Has spark and has fuel going to the fuel rail but fuel is not going through injectors. HELP!!!
Old Jul 27, 2019 | 05:01 PM
Since the computer from the info it gets sends a ground to an injector, if that injector has power to it and now it gets a ground signal it should open.
The easiest thing to check is the fuse for the injectors . If it is open all the ground signals in the world won't make the injector open.
Let's see what you find.
Old Jul 28, 2019 | 03:29 PM
The fuse is the first thing I checked.
Old Jul 28, 2019 | 07:51 PM
Do you have power at the injectors with the key on?
Old Jul 28, 2019 | 11:50 PM
Yes they do.
Old Jul 29, 2019 | 04:23 AM
One simple test,
Either use a voltmeter or test light.
Clip ground lead of test lite to a battery positive source,then see if any injector is getting a ground signal from the PCM. The engine needs to be cranking to see this. You will either be getting a ground signal to fire the injector or you won't, need to know that.
Also you must have fuel under pressure at the injector , just fuel presence is not adequate for running. Use a fuel pressure gauge to check this.at the fuel rail schrader fitting.
Let us know what pressure you are getting..
Old Jul 29, 2019 | 03:54 PM
One simple test,
Thank you.
Old Jul 29, 2019 | 05:11 PM
For your vehicle engine,you should have 35-40 psi fuel pressure at the gauge connection with just the key on engine off (KOEO)
Old Jul 31, 2019 | 10:08 AM
[QUOTE=hanky;114545]One simple test,
My mechanic gave up . Last I heard there was 40 psi fuel
Old Jul 31, 2019 | 07:06 PM
It is unfortunate when a mechanic gets discouraged and we almost all have been there at one time or another.
I suspect giving you these things to check and do are probably not that helpful since you may not have the tools to do the checks.
Is it possible for you to have someone else look at your vehicle?
I would be reasonably sure there is an electrical problem affecting the fuel system, but it doesn't make much sense describing procedures if you cannot perform them.since you don't have the necessary tools.
alex5357aa
Aug 9, 2013 12:15 PM
Tomson1
Oct 22, 2008 06:36 PM
sprdty21921
Feb 27, 2008 02:06 PM
O2THPIC
Oct 19, 2007 01:05 PM
huntingsmoke74
Sep 11, 2005 06:13 PM
