O2 Sensor Fault after Fuel Pump Replacement
Old Feb 27, 2023 | 07:43 AM
erikweige's Avatar
Default O2 Sensor Fault after Fuel Pump Replacement
2013 Explorer XLT, 3.5 L V6. I recently had both fuel pumps replaced and when I picked it up the Engine Service light was on with an OBD code for a downstream O2 sensor needing replacement.
I understand the fuel tank needs to be removed to service the fuel pumps. Could any of the required work for the fuel pump have cause damage or disruption to the Bank 2 downstream sensor?
Old Feb 28, 2023 | 01:52 PM
We would like to think not, but since we were not present when the work was done not smart to speculate without actually checking physically/
Old Feb 28, 2023 | 02:14 PM
erikweige's Avatar
Does removing the fuel tank require dismantling the exhaust pipe? Is the downstream sensor on the exhaust line and maybe got bumped?
Old Mar 1, 2023 | 04:46 AM
raski's Avatar
In some situations, an exhaust hanger might have to be unfastened to push a tailpipe out of the way, that will not cause a problem but I believe your situation is pure coincidence.
Old Mar 1, 2023 | 07:47 PM
erikweige's Avatar
OK, thanks. Appreciate the response.
jsorto1
Apr 25, 2021 04:44 PM
rlevy64614
Jun 30, 2020 06:39 PM
IguanaGrrl
Jul 25, 2009 09:44 PM
danny3806
Apr 24, 2007 07:14 PM
