13 f150 5.0 oil pressure sensor problem
Old Jun 21, 2023 | 07:53 AM
Joetaylor100's Avatar
Default 13 f150 5.0 oil pressure sensor problem
I have a 2013 cord f150 with a 5.0. The engine has a 173k miles on it. My problem- once the engine is at normal operating temperature and I stop at a stop light or bring the engine to idle I will randomly get a low oil pressure warning. This is a random thing not everytime. I have changed the oil pressure sensor with a standard ignition part and it fixed the problem for a short period of time but the issue has come back. I have also noticed my engine idle in drive seems to be a little low maxing out at 500 while in neutral it’s 6-700. My questions are-
what could be the problem? Should I switch the oil pressure sensor to a motocraft part? Am I completely missing something? Do I need to clean the throttle body or raise my engine idle? Or is this a bigger issue I need to be worried about?
lastly the engine does not seem to actually be loosing oil pressure. I have no new ticks or noises and engine performance has stayed normal. I have a video of the problem I can attach too.
Old Oct 5, 2023 | 12:21 PM
PH2011F150's Avatar
Default Same problem
I have the same problem. 2011 F150 5.0 with 275,000 km . Did you ever solve the problem ? I have read somewhere that it is a low idle problem caused by gunk buildup in the throttle body. Have you tried cleaning yours ?
Old Oct 5, 2023 | 03:32 PM
Let's face it guys, the mileage is really up there. This is where past service pays off.
Personally , std parts are OK. I would for the price ,try a Motorcraft sending unit. What type and grade motor oil are you presently using?
Old Nov 26, 2024 | 09:30 AM
crow.aaronk@gmail.com's Avatar
I’ve had this same “oil pressure” message for two years now. After reading this thread I decided to clean the throttle body just to see what it would do. When I pulled the intake hose off the TB looked fairly clean so I almost stopped and put it back together. But I figured might as well continue on. The back side was a little dirty, but not bad. I cleaned it all up with brake cleaner and put it back together. 3 days of driving and the low oil pressure message has not came up.
Old Nov 27, 2024 | 12:36 PM
Thank you for the info.
Steve Eff
May 4, 2021 03:10 PM
newtoFord
Mar 3, 2008 08:36 PM
newtoFord
Feb 28, 2008 07:25 PM
heyitsmesmitty
Jun 13, 2007 04:02 PM
paguy215
May 20, 2005 05:34 PM
