1985 F-150 clutch
Old Oct 19, 2016 | 04:54 PM
1985F150Bruce's Avatar
Default 1985 F-150 clutch
I have a 1985 LT in line 6 with a granny 4 speed. I replaced the clutch pack and slave cylinder.
Upon finishing those repairs I tried to purge the air out of the system. Cracked the plug and nothing came out. There is fluid getting to the slave cylinder. The slave cylinder pushes on the fork.
When running it won't go into gear. You can start in gear and shift through all the gears. Same as when the engine is off.
Would the master cylinder be at fault?
Old Oct 19, 2016 | 10:33 PM
primem's Avatar
you have air trapped in the system. the master will have to be removed, held on an incline and bench bled; reinstalled and then bleed the entire system. google bleeding a clutch
Old Oct 20, 2016 | 05:32 AM
Okay thank you. I will try that
Old Oct 20, 2016 | 06:27 PM
I did the procedure and I am still having the same issue
Old Oct 20, 2016 | 09:09 PM
Is the pedal firm and high up on the pedals travel? Meaning no 'drop' off in/on the pedal travel before it starts to build pressure against your foot? With a helper depressing the clutch, is or does the slave extension seem to be full travel.
Pumping the pedal, no improvement on the release?
jwald
May 22, 2013 01:52 PM
Maverick Mike
Oct 28, 2012 07:26 PM
fordmandodgefan
Aug 8, 2010 12:20 PM
jpoore_82
Sep 29, 2009 09:55 AM
camshaft01
Dec 24, 2008 03:16 PM
