1988 F-150 battery drain
Old Jul 22, 2011 | 01:36 AM
Haponot's Avatar
Default 1988 F-150 battery drain
I have a 1988 F-150 with a straight 6, It seems to have a 3 volt draw from the battery with everything disconnected. Not sure if it is from the computer, if it even has one, or what it might be from.i could use a little help! thanks
Old Jul 22, 2011 | 11:36 AM
When you say everything disconnected, if you actually disconnected everything(pulled all the fuses) then the only thing left is the alternator. If you disconnect the alternator and the drain is gone , you will need to replace the alternator itself. Let us know what you found.
Captain B
11
Apr 26, 2023 01:07 PM
NosT
Aug 17, 2011 03:35 PM
rdoble
Sep 6, 2009 07:39 AM
northerner
Mar 26, 2008 04:08 PM
ATASTEVENS
Jun 25, 2007 05:07 PM
