1988 ford f150 xlt lariat 302 5 speed manual
Old Nov 19, 2020 | 11:31 PM
andywould90's Avatar
Default 1988 ford f150 xlt lariat 302 5 speed manual
Hi i am a new member so sorry if im doing this wrong anyway my problem is that i think there is something wrong with my clutch i was driving home and pushed in my clutch pedal and it went soft and i put in in gear anyway and nothing happend so i rolled to a flat spot and checked the fluid in my slave cylinder and it seemed to be fine when on good flat ground i can put in first gear and let out on clutch and can feel it catch and will start to slowley pull itself same in reverse main question is what do i need to fix or replace thanks
Old Nov 21, 2020 | 05:49 AM
raski's Avatar
I suspect worn bushings/components with your pedal box under the dash.
Old Nov 21, 2020 | 06:47 AM
Your vehicle most likely has a clutch master cyl; and a clutch slave cyl inside the bell housing of the trans.
It sounds like there is a problem with the slave cyl. To replace that you may need to remove the trans, and while it is out, replace the clutch pressure plate, clutch disc, release brg. and pilot brg in the flywheel. .You probably will need to replace the slave cyl also. Once this is all done, you will need to bleed all the air out of the clutch hyd syst and will have a good functioning vehicle.
This is not a job for an inexperienced person without the proper equip.
Old Nov 21, 2020 | 10:56 AM
Well i pulled the ruber cover off side of tranmsision and inside you can see the pressure plat ig it is and a mouse had built a nest in there after it sat in a feild for about 2 year and after i got it running and started driving it it slung it around and got packed in the little groove where plate sits when clutch disengaged and wasnt letting it come all the way back had somebody hold clutch in and i dug it out with long j hook and fixed the problem. It could be raining ******* and if get hit in the head with a dick i swear lol thanks for all the help and replys
Old Nov 21, 2020 | 01:45 PM
You are on the ball checking it out as you did.
It might take a while for the slippery mouse stuff to go away, but sometimes we get lucky.
Nice work !
Old Jan 2, 2021 | 01:43 AM
Pulled transmission removed clutch and cleaned pressure plate problem solved now i have a voltage problem lol
Old Jan 2, 2021 | 04:21 AM
raski's Avatar
Question
I hope doing all that work, you should have replaced the disc, pressure plate, throwout and pilot bearings while you had the transmission out. I believe in 88 they started putting the slave cylinder inside, I would have replaced that too and you likely would never have to worry about the clutch for the remaining life of your truck.
Old Jan 2, 2021 | 04:24 AM
I thought about it but All was in good condition didnt really see the need to its working fine but yeah i see your point
Old Jan 2, 2021 | 09:22 AM
If the voltage problem is still present,
Sometimes there is a wiring harness that sits over the area where the trans meets the engine, and that harness sometimes gets pinched between the engine and trans watch out for that, also there may a ground wire that was held in place by one of the trans housings bolts, make sure that wire is connected .
Curiousforddriver
Aug 23, 2013 02:02 PM
87ford
Apr 20, 2013 05:26 PM
bgrosset
Mar 7, 2013 09:02 PM
big_pete21
Dec 30, 2011 06:17 AM
adb135
Sep 18, 2006 11:29 PM
