2001 F-150 Start problem
Old Apr 25, 2007 | 10:21 PM
Avocado Mafia's Avatar
Default 2001 F-150 Start problem
I have a 2001 F-150 with 92K miles. Never had a problem until today. Truck wouldn't start, but was turning over like normal, so it's not the battery. Either wasn't getting fire or fuel. I made sure all the fuses were seated; basically, I just pushed on all of them. Then the truck started. Five hours later, the truck wouldn't start. Opened the fuse box (the one in the cab on driver's side), pushed on the fuses again, truck starts. Later, I pulled and inspected all fuses, inside the cab and under the hood. They all look good, all were seated properly.
I doubt my fidgeting with the fuse box really did anything, so I'm lost. Could it be an electrical problem? Can a fuel pump 'act up'? Any ideas?
Thanks.
Old Apr 25, 2007 | 11:03 PM
Default RE: 2001 F-150 Start problem
One other observation....
Just tried to start it again...the problem is back. This time I noticed the THEFT light blinking rapidly, never noticed that before. Tried myspare key, started right up. Killed it, tried the 'suspect' key...started right up. WTF? Can my key be the problem, maybe going bad? I'll carry both sets tomorrow just in case. I'm lost.
Old Apr 28, 2007 | 03:53 AM
91explorer12323's Avatar
When it is running do you get any kind of check engine lights coming on or anything? Im just curious if you have any codes stored in your computer that may explain the problem. sounds like a bad ground in the engine system. let me know if the engine light comes on or not and we will go from there.
Old May 4, 2007 | 12:46 AM
papa5100's Avatar
I have a 2003 F150 4X4 4.6L engine. Mine was doingf the same. It was caused by a leaky windshield that shorted the fuse block and the gem module that sits on top. (PATS system, cranks but no start)
manning
May 26, 2023 07:21 PM
mayor
Nov 18, 2012 06:46 PM
ronb0626
Aug 27, 2006 04:12 PM
byron
Jul 21, 2005 03:00 PM
2001F150
Mar 10, 2005 12:32 AM
