2000 f-150 start problem
Old Aug 25, 2006 | 04:09 PM
ronb0626's Avatar
Default 2000 f-150 start problem
I have a intermentant start problem on my 2000 5.4 Sometimes it will not start nor will the radio work. I can start it by crossing over the starter Relay. I have replaced the relay in the fuse box I did check and I was unable to find one on the relay box on the drivers side fender. I have also replaced the start relay on the firewall that is connected to the battery. I have also replaced the Ignition switch. I have noticed that when the key goes to start I am unable to get a voltage at the remote wire from the ignition switch, at the relay. Hope someone can help with this problem.
Old Aug 27, 2006 | 04:12 PM
Mulletman's Avatar
Default RE: 2000 f-150 start problem
Carefully check the cable that connects to the starter. These are known to corrode and cause all sorts of problems.
sturman3
Jan 22, 2013 05:07 PM
VanHaulen
Dec 6, 2012 08:31 PM
iownslaves
Apr 1, 2008 06:03 PM
cgl
Dec 9, 2006 07:36 PM
cgl
Dec 8, 2006 07:38 PM
