2002 F-150 5.4 Crank No start or spark
Old Apr 6, 2014 | 08:16 PM
drivewayford's Avatar
Default 2002 F-150 5.4 Crank No start or spark
I have a 2002 F150 5.4L (VIN-L) that has been sitting in the driveway since February. I have been a mechanic for 30 years for large commercial trucks, and my own truck has me stumped. I'm sure I've forgotten something but I'll try to list everything I have tried so far. It started with crank no start, no check engine light, checked for trouble codes got a trouble code for the CHT(cylinder head temperature) sensor.
Replaced the CHT sensor. Cleared codes.
Dash lights up fine, shows mileage, and anti-theft is not flashing while cranking.
Fuel Pump does not seem make any sounds. Hit the tank with a hammer. Nothing.
A little fuel comes out of the schrader valve on the fuel rail when I push on it. I have not checked it with a pressure gauge.
Attempted to start with ether, nothing, so I'm assuming no spark.
Fuel pump inertia switch isn't triggered.
Checked several ground connections to the frame and checked ground connections in the PCM harness. All have less than 5 ohm resistance.
Unplugged and plugged back in cam shaft sensor.
Checked voltage on the TPS(throttle position sensor) I'm unsure about the results, if the TPS was bad wouldn't it just idle funny and/or stall?
Fuel Pump and PCM relays in the underhood fuse block appear to be good. All other fuses and relays appear to be good. I have been swapping the relays with one I think is good, although. Searched all over for additional relays, and found 3 inside the cab behind the passenger air-bag. Can't seem to find anything in the Haynes/Chilton manual that lists what they do. They are about half the size of the fuel pump relay.
Manually grounded the fuel pump relay, relay clicks but I don't hear a buzz from the fuel pump. Id like to run 12V to the fuel pump directly to see if that's my issue, but I'm not sure where to connect it without frying something important.
I bought the alldata.com DIY guide for my truck and it hasn't helped much. I have read extensively about others with similar problems and I just don't know what to do next.
My main question here is, if the fuel pump is bad, would that stop the spark plugs from working? I'd rather not replace the fuel pump without being absolutely sure.
Rogerseric
Aug 12, 2011 12:34 PM
1986302V8
May 23, 2011 03:27 AM
jkmo
Jan 16, 2011 06:21 AM
johtwe
Jan 24, 2007 01:50 AM
