2005 F150 5.4 3v O2 Sensors
Old Sep 30, 2018 | 11:13 AM
3rdRateRedneckMechanic's Avatar
Unhappy 2005 F150 5.4 3v O2 Sensors
Okay. So I was having a low power concern for several months and did some research. thought it was plugged cats. so before I spent a mint to have them replaced, I decided to just gut my exhaust from behind the cats back so I could take a peek up in there. Apparently the cats are fine, but i removed all the exhaust system behind them including the downstream O2 sensors. Come to find out, my upstream sensors were bad, so I changed them sons out with a quickness hoping to solve my low power and horrid mileage issue. After the swap, I cleared the codes and she ran like a dream...until the next time I fired her up and started driving. For some reason it's still throwing upstream sensor codes. I expect it to throw codes for the downstream ones because they're not connected but it shouldn't be throwing codes on brand new sensors. It's the same thing every time. I can clear the codes and it will run great until the next time I fire it up, then it will throw codes and default to running rough and rich. Any ideas? Tyfys in advance.
Old Oct 1, 2018 | 03:04 PM
Can you provide the codes you rec'd?
The percentage of sensors being the reason for codes is not a large as one might expect.
I'm sure you know if Ford could have done away with the downstream O2 sensors, (saved a bundle) they would have. !!
Until you put everything back as it should be , sensors present and connected, there is no sense attempting to offer any other suggestions.
As much as we might like to eliminate /bypass some components , those darn computers know right away when we cheat !!
Soooo, why not go the right path and do it right , when done correctly and working correctly the manufacturer paid their engineers plenty to get it close to performing pretty good.
What do you think?
Chaseutb
Nov 6, 2016 07:13 PM
/m3
Jan 26, 2015 03:07 PM
ghoghunter
Aug 23, 2009 06:53 PM
jeffandteneka
Feb 21, 2007 04:09 PM
jeffandteneka
Feb 12, 2007 02:24 PM
