2005 Ford f-150
Old Feb 18, 2020 | 06:59 PM
James Armstrong's Avatar
Default 2005 Ford f-150 4.2
I I'm having an issue with the lack of power in my F-150 I have changed spark plugs spark plug wires all 4 O2 sensors the mass airflow sensor crankshaft sensor camshaft sensor and throttling positioning sensor the truck will now I know smoothly I put it in gear drive or reverse and I get a bad vibration and no power can anyone help me with this
Last edited by James Armstrong; Feb 18, 2020 at 07:07 PM. Reason: Forgot to post motor size
Old Feb 19, 2020 | 03:23 AM
Is the lack of power on take off, cruising or higherr speeds?
Different times can be affected by different causes,that is why it is important to get some idea of just where the range is.
Some folks describe a misfire as a vibration ,could this be the case here?
Two things, I wouldn't shell out anymore $$$$ until you have some idea as to just what you are after and the question of where did you get the replacement parts. Some stuff out there is defective right out of the box. We should be able to provide some guidance , just need a little more info.
Any check eng lite or codes in the vehicle computer?
Audessa D. Graham
Jun 2, 2017 06:20 AM
hfd
Dec 31, 2013 07:08 AM
CountryMarine452
Feb 28, 2012 06:45 AM
ptclink
Oct 7, 2009 11:43 PM
mikex
Jan 11, 2007 02:22 PM
