2011 F-150 parking brake light
Old May 17, 2024 | 09:38 PM
Fred's Fords's Avatar
Default 2011 F-150 parking brake light
My 2011 F-150 parking brake light stays on. Looks like the cable is too loose to pull the rubber pad up to the switch. Is there an adjustment to tighten the cable to pull the pad up to clear the parking brake light?
The pickup is not used often, just use it to pull our 23 ft travel trailer. 101000 miles.
Old May 18, 2024 | 06:49 AM
Cables do stretch and there is usually an adjustment under the cab to take up the slack in the cable.
If the foot brake pedal seems low, the rear shoes for the parking brake may need to be adjusted first.
Suggest you have a good shop check the brakes for wear and possibly require some addl work.
Old May 18, 2024 | 09:20 AM
Thanks. I will crawl under it and check for the adjustment.
Dave Lombardo
Nov 25, 2021 04:47 PM
Zipdog94
May 31, 2020 09:51 PM
wheelerbuffy
Mar 16, 2014 08:21 AM
lobo46222
Apr 14, 2009 07:33 AM
mad.72
Mar 27, 2007 04:40 PM
