4r70w transmission
Old Dec 8, 2018 | 11:07 AM
Niveknosliw's Avatar
Default 4r70w transmission
Does anybody know if the internal wiring harness of the transmission would keep it from fully engaging in gear if some of the wire is exposed
Old Dec 8, 2018 | 03:23 PM
If you see something that is out of place or not normal [bare wire(s) ] , smart move to repair that first to eliminate that as a possible problem that could have you chasing around for something else . If it is corrected ,then you know it cannot be the problem.
Old Dec 9, 2018 | 02:19 PM
Default Wire
The wiring is the only thing that I have not replaced in the transmission
Old Dec 9, 2018 | 03:32 PM
Valve bodies were troublesome. Did you open it up for the same reason?
Old Jan 31, 2019 | 05:08 PM
Default 4r70
had the valve bodies replaced wiring replaced and had to replace the drive clutches again still haven’t tried it
Old Jan 31, 2019 | 05:23 PM
Electrical/electronics can be funny sometimes and do things we would not expect. so we usually don't let a "possible future problem" go and hope it will not cause any problems up the road. The old saying still goes, "Do it right and do it once". Let us know how it works out for you. Appears you are doing it right !!!
Grnmstr
Feb 10, 2019 08:17 PM
Jeffbodden
Jan 19, 2019 12:23 PM
Erb
Dec 16, 2018 05:18 PM
eeguy1953
Jan 11, 2009 01:37 AM
lthacker
Mar 5, 2007 10:59 PM
