Battery draw while key is off :'( 2011 f150
Old Jan 20, 2020 | 10:44 PM
Nick Rife's Avatar
Default Battery draw while key is off :'( 2011 f150
So my battery has been dying overnight sometimes even sooner, I was under the hood after turning off the engine and there is a very quiet wine/beep noise that stays going steady , so I pulled fuses 1 at a time and the noise stopped when I pulled pcm fuse. Not sure if this is a problem or normal .. I certainly don't remember the wine sound. Any help or tips to point me in the right direct would be amazing ! Thanks
Old Jan 21, 2020 | 03:23 AM
Did the whine sound come back when you put the fuse back in?
If it did, that will be easier to find.
If not, the system resets and it will be impossible to locate the problem because it no longer exists.
There is a special procedure, a little lengthy, to pin down a parasitic drain . You might type in "Locating a parasitic drain" and see if you can utilize the procedure.
Old Jan 23, 2020 | 01:11 PM
Nick Rife's Avatar
The wine goes away and the battery no longer dies after I pull the fuse and put it back in.
Gharris03
Apr 25, 2020 01:56 PM
rybad
Dec 28, 2017 03:24 AM
Stormchaser
Jun 16, 2017 07:32 AM
VansRule
Dec 20, 2011 03:30 PM
rdoble
Sep 6, 2009 07:39 AM
